1 - 10 of 10 Posts
Okay, I know that many East coasters will get a laugh out of this "California rust" problem...
My California car had two areas of rust, the first being the driver's floor pan which was caused by being parked with a broken window for many years by a PO. Replacing that was fairly straight forward...
But what would you do about this? Below is a picture of the bottom edge of a 69 deck lid (trunk). This has been media blasted and coated with DP90...
I am concerned that any welding to this area will do more damage than good by warping the top side.
Suggest away!
http://forums.vintage-mustang.com/files/attachments/1203815958-Decklid_rust.jpg
Larger image
Thanks in advance,
-Rory
I would use a bead of seam sealer like many decklids and hoods have (and all SHOULD have had) to keep moisture out of that seam anyway.
That area is a good candidate for Metal2Metal or similar filler material with aluminum in it. I wouldn't try and weld those pinholes or rust-pits. Sometimes you gotta do what is expedient and not ruin the panel itself.
VMF Full-Timer
+1 :thumbsup:
Discussion Starter · #6 ·
After seeing some of the restorations on this site, I was almost embarrassed to post this question ;)
-Rory
[quote='70 StangMan]
+1 :thumbsup: [/quote]
Yelp, no welding needed.
use all metal. i would also make sure you seal the deck lid from the inside. i like to take the left over DP and pour it inside the door seams and so on to help seal them up.
1 - 10 of 10 Posts
