1 - 9 of 9 Posts
I was looking for more identification from the engine in my 65 Mustang. It is an I6, most likely 200ci. On the driver side of the valve cover is an emission systems sticker. In the bottom right-hand corner there is the following code: C80E-9C485-B
Attached to the coil there was a metallic tab which had the following codes:
200 68 9
8-B K24 J
Any help in deciphering these codes is appreciated. ;)
Thanks,
Justin
October 24, 1968 200 cid for the tag but you need to check the casting date codes to check when the engine was cast
1 - 9 of 9 Posts
