Does anyone know the common wheel hub diameters that are used on Fords?
Any guides (applications/years) for when the change was implemented?
I am pulling together my plans to have an 8.8 modified to fit my 67. I noticed that there are different axle hub diameters on the 8.8 axles. The hub I am refering to is the seat that the rotor/drum and wheel center on.
I did a search, but did not find this information.
Thanks,
Glenn
I can't help on dimensions but I do know the hub diameter of an '86-'93 Mustang 8.8 is smaller than the '94-'98 Mustangs. The '87/'88 T-Bird Turbo coupe 8.8 hub diameter is the same as the '86-'93 Mustangs also.
Hope that helps some.
Dean T
I have not come across that information before. I did realize the housing to axle end is longer on the 94+ due to ABS. Thanks.
Glenn
