Hi guys, long time no post...
Has anyone ever heard of someone widening their wheels? I love my keystone klassic rims, but they are just not as wide as I'd like in the back. I am wondering if there are ways to widen my existing wheels, or if i have to try to find some wider keystones, (or worse, switch and buy different rims). Also how wide do you think I should go? I really have no idea how wide is good enough, I just know I need more traction back there, cuz right now I'm just slippin...
Thanks a lot in advance,
Kevin
Discussion Starter #2
I have actually heard of this. Try some searches for racing wheels. I believe that circle track guys used to do this, but I can't recall.
One option would be buy different (wider) tires, if you are running fairly narrow ones, like P205.
I dont believe its actually possible to widen existing wheels - and no matter how good you are with a welder, probably best not to try!
If you really need more traction, go with very good quality tires, or bite the bullet and buy new rims (like i did! /forums/images/icons/smile.gif)
Either way, good luck!
Gary
It can be done but I can not remember where an older friend had it done. He had some stock chevy rims done for his narrowed rear end.
I've seen this done only on stock steel rims. No problems. We had VW rims split into thirds and widened. Put them on a sand rail.
On Keystone Klassics? Not likely.
