Between the equalizer bar and a mounting tab under/behind the master cylinder? My late '66 has a mounting tab, and the equalizer bar has no hold provision for the spring. My '65 has a hole for a spring, but no mounting tab on the firewall.
Also, what is the correct spring size for this application?
Thanks,
Troy
65's used a spring under the car from the shock tower to the clutch fork.
66's used the spring on top in the engine compartment from the firewall to the z-bar .
Im not sure if there is really a correct size.
The one I put on my car was from a universal spring pack I got at the parts store. Just make sure the spring has enough force to pull the throwout fork & bearing off the Pressure Plate fingers.
