I just bought a new rubber grommet kit for my 66. Does anyone have a map of where they are all located. I know the logical ones....like under the rear seat, the ones to access the front seat bolt....can anyone help.
Administrator
If you get a copy of the Osborn manuals, you can see the locations in there. They go in the frame rails, fender walls, etc. I've even double checked my coupe with the manuals for the grommet placements.
A few locations are the trunk, behind the rear seat, the brake and fuel lines, the sides of the cowl behind the fender and the front floor boards.
It’s right in the description of the kits
  • Eight (8) Front Fender Apron Plugs
  • Two (2) Frame Rail Plugs Near Trans Crossmember Plugs
  • Two (2) Top of Cowl Under Fender Plugs
  • Eight (8) Seat Nut Access Plugs
  • Two (2) Side of Cowl Plugs Behind Kick Panel
  • Two (2) Trunk Floor Plugs
  • Two (2) Frame Rail Plugs Near Sway Bar
  • Two (2) Rear Floor Pan Plugs
  • Two (2) Front Frame Rail Plugs
  • Two (2) Rear Shock Access Hole Plugs
