Where does the negative cable on a 68 mustang go I had it bolted on with the rad and was just wondering the proper location
thanks
There should be a lug on the front of the engine, just below the #1 exhaust manifold. It should have a hole drilled and taped. Be sure you clean all paint off the lug before you conect the cable. Alos, be sure to attach a strap from the rear of the same side to the body. This grounds the engine to the frame....Very Important...
You might also consider a second ground wire (12 gauge or so)from the battery directly to the body. This helped us solve some audio problems.
