1 - 17 of 17 Posts
Return spring on top side of clutch equalizer bar to firewall? It looks sorta like that spring on my 66.
Since the OP did not place a quarter next to the spring it is difficult to judge the size of it. It could be a throttle spring or a clutch spring. If it's a clutch spring I believe it hooks into a small hole in the outer end of the clutch release lever.
reminds me of a seat cushion spring. Its too short for a clutch return spring.
The early cars had a clutch return spring in the engine compartment. It was phased out 8n late 65 or 66. It connects to a tab on the firewall and t9 the to of the Z-Bar
1965 Mustangs with the adjustable Pedal-To-Equalizer Rod and fixed length Release Rod did not have the upper spring on the clutch linkage. Look at the Retracting Spring that attaches to a hole in the end of the Release Lever. I think the spring in the OP's photo is the Retracting Spring.
If, by early you mean April of 66 You are correct. That is my build date and my car has the little tab and spring.
PS I am the second owner of the car. Had it since 1977
Discussion Starter #14
I believe it is the assist spring. I already have the retracting spring assembled.
It is too light to be the under-dash assist spring by a country mile. No way, no how.
If the bent end (lower in the photo) were re-formed properly, it would be appropriate for the under-hood return spring between the upper equalizer arm and the firewall.
Discussion Starter #16
Where in the firewall?
Mid to late 66 Mustangs had the spring mounted between the top of the equalizer arm and a tab just below the master cylinder. It can be really hard to see unless you go looking for it. Early 66 had no such spring, like the 65 they had a really long spring from the release lever to the shock tower.
1 - 17 of 17 Posts
