Hello, I have a Question.
I'm in the process of putting in a new fuel system for my car so as of now my gas tank is a 2 gallon jug sittin on my driver side horn (64.5) any way i was takin my car up to the shop (so they could run a new gas line from tank to fuel pump) and i ran into a little problem. I Don't have any Power!! what i mean is the car only shifted once (its an automatic) and that was going down hill and when we had to go up the hill the pedal was all the way to the floor and we barely made it up the hill
Whats Wrong?
my father and i though that maybe the vaccum advance in the distributor isnt working and there fore throwing the timing WAY off could this be or is it somethin else?
Thanx
64.5 Coupe
260 V-8
Even got the good ol' generator
And the first hood ornament ive ever seen on a mustang
Does you makeshift gas tank go through the fuel pump or just gravity feed? It needs to go through the pump.
Start with the basics.
electrical (Points, cap rotor, timing)
fuel (pump, filter, choke)
MotorHead
http://www.alltel.net/~motorhead/mustang2.jpg
It goes through the fuel pump
64.5 Coupe
260 V-8
Well, you do have an F-coder with a one barrel, yes?
Add to that a green dot tranny and things can get pretty sluggish if you don't pull the trans down into the second Drive position...
Try that first if you haven't already...
And, when going up a hill, pull the shifter all the way down....
If you have the ability and equipment to check the engine's state of tune, please post back and we'll go through a few basic procedures...
Good luck!
Pat
Ive got a F coder but it has the 2 barrel
so even though i have an auto i have to switch gears every time i go up and down a hill (or did i just misunderstand)
also do i keep the trans on the green dot for normal driving?
and sorry but i dont have anyequipment like that
thanx
64.5 Coupe
260 V-8
FWIW, I keep the shifter of my D-coder in green dot all the time when I'm driving....
If your downshift linkage and valve are working correctly, flooring the throttle should cause the trans to downshift...if they don't, you'll have to pull the lever back to manually downshift the trans on a hill or to pass...
Ok....get your fuel line installed, then we'll work on getting rid of the hitch in your git'along...*G*
Pat
ok
Thanx ill take you up on that offer
64.5 Coupe
260 V-8
