1 - 20 of 27 Posts
Ford Mustang fastback GT390
Looking for your thoughts on which carb & CFM would best suit my engine.
351c 4barrel, Edelbrock 351 torker single plane, high lift cam, full msd, long tube headers 3” collectors twin 3” exhausts.
pulling 265hp to the rear wheels.
Tell me what carb you would put on.
cheers Mark.
Belky, a 750 cfm will do fine. Do you have the 2760 torker ? What camshaft do you have ? You might be able to improve driveability with a wider cam and a Blue Thunder dual plane, if you're interested. If you're happy with the single plane, rock on. LSG
Depends on a lot more than you've posted, but if it's spaghetti on the wall you want, it's spaghetti on the wall you get.
For me, a Holley 750 double pump - mechanical secondaries. My right foot knows where the secondaries come in, it's not an on/off switch.
FWIW, 265 at the wheels with the equipment you describe is awfully low.
Just in reference to the horsepower numbers. I agree that that sounds low for a Cleveland with that much done to it. However, the type of chassis dyno, the type of rear tire, automatic transmission can all effect those numbers.
As for the carb, if you don't have much for gears and have an automatic some type of vac secondary carb in the 650-750 range would probably work. Pick the brand you are most comfortable tuning.
Discussion Starter #10
Yes it is the 2760 torker, does this require the turkey pan?. Also what are the screw in studs underneath the intake for, I’ve attached some pics showing the intake & the cam spec.
let me know your thoughts.
Discussion Starter #11
Thanks, just found this from a folder that came with the car, hows this sound.
I run a 670 Street Avenger on my 324 rear wheel horsepower 302 with C4 auto. With an auto, Vacuum Secondaries are a good idea. You can always do the ziptie trick if you're doing any drag racing.
I agree that 265 horsepower seems low for you. But if you are happy with that I recommend the same carb as me. They're good out of the box and have decent features. I got a factory-refurb off Ebay for pretty cheap. If you are actually shooting to maximize your power with that engine I might suggest a 750.
Discussion Starter #13
I ended up buying the edelbrock 1406 AVS2 650CFM, I replaced the Holley 4160 750CFM FOR THIS. I’m thinking now that I’ve made a mistake with the choice of Carburettor ?.
Discussion Starter #17
Just me, but I'd be looking for a nice FE to put back into that car!
If I could find a decent 390, either in bits or complete I would seriously think about putting it in.
65 Fastback 289 4 spd, 65 convertible 5.0L 5 spd. 3.73 8.8
cheers Mark.
I built a351C with the same cam, 3000 stall, C6, 3.50 gears and I always have 3 or 4 Holley carbs laying around. What I have found is that they like a bigger carb then say a 351 W. I found a 780 worked good, But I like double pumpers and 750 worked great.
Im new to the game, but wouldnt your carb selection vary dependent on what you are using the car for. Is this a track car or or street car? However the think the general consensus is for that car you could go with a 750. But a lot of people over carb their engines. IJS
1 - 20 of 27 Posts
