1 - 9 of 9 Posts
Ordering new pipes this week for my '67 289 convertible.
Which header/exhaust combo do you guys recommend and from who? Looking for something throaty but not overkill. Something classy.
I need some help.
Thanks!
You got lots of options. If you want something classic you can go with shelby Try-ys. Hooker IMO is good source. Different options for different power levels. Not very expensive for the lower power series. hedman is another... Whatever you do I highly recommend longtubes. Flowmaster IMO makes the best sounding mufflers especially for the money. I think their main advertising slogan is "that classic muscle car sound." Flowmaster 40 series However from what I hear they do not flow the best. Headers with a 1 3/4" primary's and 2.5 collector should be all you need. 2.25" piping before or after the x-pipe that you should buy will do the trick.
I use jba shorty's (14 gauge with ball socket connections that do not leak) and 2.5" exhaust with magnaflows. I get compliments all the time on the exhaust note.... they do not drone at cruise speeds like the flowmasters (dronemasters). I had a set of super 44's and could not get them off the car fast enough. Unless you are running 500 hp 1 5/8 with 2.5 inch pipes is still overkill.... you don't want 1 3/4 primaries. Since it is a vert I am guessing you want a mild tone to enjoy cruising in which the magnaflows will provide.
I saw a thread awhile back on this subject and the sound of the car I liked the most was a guy who put on tri-Y's and glass packs. It sounded great and I bet it wasn't very expensive. Do a search on tri-y's and you can probably find it. There was a sound clip from him in that thread. I may be able to find it if you can't.
I'm also using the JBA mid length headers. I believe the part number is 1650SJS. They are very nice. I also had dronemasters and ditched them for Dynomax Ultraflo which is similar to Magnaflow, but sounds a bit more aggressive. My piping is 2.5, but 2.25 is plenty for stock or mild small blocks. I have an H pipe. It sounds nearly perfect.
Thanks guys!
What do you think of this kit from CJPony? part #EXK2G
It's all 2-1/4 with Petronix Tri-y headers?
Like I said before, not looking for anything crazy, I'm just replacing the stock single system...
HI! for what it's worth I've been driving my 2bbl with single exhaust 289 '68 coupe for over 30 years and recently swapped to repro - HI-PO cast manifolds and 'stock' GT.350 dual system from CJ Pony Parts - The new system DEFINATELY improved the enjoyment of the car - performance, tune etc. Why cast manifolds? Simply because I'm not a fan of headers - for many reasons. Cast was good enough for K-Codes and GT 350's so I'm in good company. You did mention classy without overkill - Good Luck with your selection!
1 - 9 of 9 Posts
