I'm planning on putting on some new styled steel wheels and fitting 205/70R 14's. Would it be best to put those on a 14x5 or 14x6 rim? Thanks! Kevin
John, thanks for the reply. I'm interested in your opinion. I currently have some old white walls in 205 70's. I'm planning on purchasing some diamondback classics dual redlines and thought about going with 195/70's to more closely approximate the original size bias ply's, but they're a bit small for my liking. I'd like to keep the tires/wheels fairly stock looking with just a little more of a substantial look. With that being said, what would you recommend? I realize it's a matter of personal taste, but would appreciate your input (as well as any other fellow VMFer's). Thanks.
Gone but never forgetten
Keep in mind, when looking at modern tire sizes, that the second number is a ratio. So a 205/70 is wider AND taller than a 195/70. I'm just a tad concerned about a 205/70 rubbing on hard turns in front (hitting the front edge of the wheel well opening). Most likely it would be fine, though.
With your current 195/70's, turn the weels as far as they'll go and see how much clearance you have. If you have over 1/2" clearance, you'll most likely be fine with a 205/70.
I actually already have some old white walls on the car in 205/70R14's. I'm not sure of the size rim, though I think they may be 14x5's as there is a decent amount of bulging. In any case, I've not had problems rubbing, but I'll measure to just be sure. Thanks again for insight. Kevin
As John said, the 205 is going to be much better suited to at least a 6" wheel. I've tried a 205/70-14 on a 5" wide wheel, and it was VERY "pinched in". Look at it this way: 205mm = (approx.) 8", so technically speaking, a 7"-8" wide wheel would actually be preferable.
In addition, unlike the opinion of many here, I completely agree with John in thinking that the 205/70 is about the tallest tire I'd run on a '65-'66 - though its certainly not out of the question by any means.
I've run 195/75's and 195/70's also (which I much prefer), though they're obviously not as wide, but I've always been more interested in a "stock" look.
FYI:
195/70-14: 24.7" dia.
195/75 : 25.5"
205/70 : 25.3"
Good luck!
FYI:
195/75 : 25.5"
205/70 : 25.3"
Good luck!
Thanks for the information. I needed the refresher in tire size, circumference, etc. The more I think about it, the more I believe I'll go with the 14x5 rim with the close to stock dual redline radial sized of 195/70R14's. My Kar is stock except for Pertronix and stealth FM conversion on the original AM radio. I don't drive the car hard, and I think I'd regret not continuing the stock look to the tires/wheels. Happy New Year! Kevin
I currently run 215R70x14 on a 6" rim with no problems of rubbing either front or back. Yeah, it looks a bit pinched on the wheel, but haven't had any problems.
