1 - 2 of 2 Posts
I have a 66 Mustang Convertible getting a 2018 Coyote engine. The engine came with a 6 speed Getrag MT82 transmission, which is extremely large requiring substantial modification to the tunnel. Not to mention the class action lawsuit being filed against Ford. I'm considering buying a TREMEC's TKO 5-speed transmission. The TREMEC won't require tunnel modification allowing me to keep the mostly stock interior. Which transmission would you recommend?
762509
The Tremec likely will require tunnel surgery. They’re a fair bit bigger than the T5 that a lot of us have.
If you’re going as far as doing a Coyote swap, modifying the tunnel is relatively minor. You should be able to just carpet over it and most won’t know.
1 - 2 of 2 Posts
