1 - 20 of 21 Posts
While I'm in the mood to post pics, I thought I would show off my engine compartment with the new RPM Air Gap manifold, MSD 6al and Blaster III coil, Mallory Comp S/S 42 distributor, and ignition wire loom. There's a new Edelbrock roller cam (227/234 @.50 .520/.520 lift)in there too, but thankfully you can't see that.
http://memimage.cardomain.net/member_images/8/web/776000-776999/776433_25_full.jpg
Sweeeet.. http://www.smileys.ws/smls/grinning/00000003.gif
Hiker...http://www.smileys.ws/smls/sport/00000011.gif
Looks great!!! Well hows it run?
Looks really cool! Tell me, what kind of carb are you running? That's the manifold I'm getting, and I've been wondering about clearance issues.
Very nice! A lot of guys put the MSD box inside the car, it makes it a little easier to change the rev limiter pills.
The intake replaced a non Air Gap, the cam replaced a TFS stage 1 cam (more duration and lift), the dist. replaced a stock dist. with a crane XR-I conversion, and the 6al replaced a 6a (the XR-I had a built in rev. limiter). All were upgrades from the previous set up. Seems to run stronger, but I keep getting this burning rubber smell whenever I get on it.
You guys are quick, two more posts before I finished the last response. The carb is a 750 Speed Demon vacuum secondary. The RPM Air Gap for a 289/302 is the same height as a non Air Gap. I didn't want the box in the passenger compartment, no room, and long wiring runs. The pill is right there on the side of the box, no problem.
It looks like a great, streetable and fun setup... I am jealous with my little C code converted to a factory 4 barrel and C4 tranny. :(
Discussion Starter #12
Thanks for the comments y'all. The pic was at a little show-n-shine at a retirement home in Portland Texas. I had to lay on the ground to get that pic.
Nice work. I can see you're on the Summit Racing "A" list. ::
Discussion Starter #14
If I'm not, I oughta be. I think they celebrate my birthday, and wait with sugarplums dancing in their heads for my Christmas wish list.
Very nice.
One question though, I may be looking at the wrong wire but are the wires from your MSD box to your dizzy running right next to your spark plug wires? MSD said that was a big "no"
Just trying to help, not trying to be a P.I.T.A. ::
Discussion Starter #17
Hi, John. Mine is a Vintage Air system. Since the car originally had AC, hooking to my original vents was a real pain, and I couldn't use my original controls. I mounted the controls in the glove box. The pulley on the compressor would rub on the hood on occasion, probably when the engine torqued over, so I had to slot the mount a little to gain a little more clearance. It works pretty good.
Discussion Starter #18
Thanks for the input Birdguy, I'll move the box wires a little further away, probably lower underneath the coil.
71 Mach1, Mcode, AOD, 4 wheel discs, Ram air, Cragars in Vermilion Fire paint.
I trust that none of the oldies lost control of their bladders with the excitement of seeing such a nice piece of machinery? :biggrin:
Thanks for the reply. That is interesting about the hood clearence, I'll have to keep an eye on that. Mine did not have air so I bought a complete system for non AC car.
1 - 20 of 21 Posts
