1 - 20 of 22 Posts
Sandblasting the body on a rotisserie in a tent I built in my warehouse. Aluminum oxide EVERYWHERE. Had a full suit and respirator and a week after was still pulling it out of my ears, nose, etc.
<style></style>
Rebuilding the new motor after I wiped out the cam bearings due to a tight timing set chain. Actually the rebuild part was fine. It was re-cleaning everything that was terrible.
Cooling system. Because it snowballed into might as well get to the steering, differential, oh look I need brakes too....et al. Still not done. And all that stuff worked for the most part.
Discussion Starter #9
Anything I have to do under the dash. Always uncomfortable, awkward, aggravating, dirty, sometimes disgusting, dangerous and when you're done there is usually nothing to show for your efforts.
X1.
I just simply don’t fit under my dash.
And my body doesn’t contortion accordingly.
A PIA.
Glad I’m done with that for the most part.
Probably the most painful was pulling everything out of the interior to replace the wiring harness, add a/c, sound deadening, and completely change the color of the interior. I cut, scraped, and nicked my hands so much and with 50 odd year old dust they became infected and swollen to twice their size for weeks. But, it looks the way I want it to now, so totally worth it.
Discussion Starter #15
I had that exact same thing happen to me..... funny
I’ve become very quick at removing the front seats just so that I can contort my body to see under the dash better
How about replacing/rebuilding the front drum brakes... only to realize that I should have just bought the front disk kit that I've been wanting for years - and then bought it and had to do the whole bleeding again! I was not happy, both with the car or myself!
Discussion Starter #19
That’s on my shortlist...
My first resto project was a 84 Chevy 4X4 that hauled a lot of fertilizer. I bought wrenches at the flea market to cut down to fit nuts and bolts that had corroded to a different size. I used the torch for the nuts that looked like cones. My advice is to avoid any vehicle from a farm, but I do miss that truck.
1 - 20 of 22 Posts
