well after a short detour (4 years) I am back to work on my 68 shelby conv. clone & am back looking into mustang Ii suspension kits. I have lost all my previously researched material & need to get an idea on who has the best kit for the least money.
any & all info would be helpful past experiences, customer service, bad points, good points.
May be it's just me, but that doesn't look like a '68. But it is a sweet looking car.
Just my $0.02, but I wouldn't put an M-II front end in. You'll get much better performance out of a modified stock system like TCP or Global West or even a Global West coil over system.
Tim
Search for heidt for older than two years and you find some threads that discuss cracking with heidt crossmember.
I just finished a MII conversion for a friend's truck this summer. I would say they are fine for a cruiser/daily driver, but i would not do it for serious track work. The control arms are very short, so the roll center moves around a lot when cornering.
As for the best kits, I am not a fan of Heidts. The upper control arm is attached to the cross member with 2 vertical bolts. It has a problem with these bolts slipping in hard cornering, which causes the camber to change. I used a Street Rod Engineering kit for the conversion I did. They use adjustable control arms to set camber, so there is no chance of slipping. The control arms look more like a TCP. The Street Rod kit fit well in a 56 Chevy truck that is was built for, and the quality of the welding and workmanship was very good.
Brian
I got mine from http://rcmotorsports.net/
No problems, great support. Now, mind you, the car still ain't done. But you did'nt ask that, did you.... never mind, I'm rambling again....
I'm thrilled with mine from Rod & Custom (http://www.rcmotorsports.net/). Willie Osborne was great to work with and it had all parts and great instructions included.
