OK, here's what I found out so far for anyone who might be interested;
1st off, Ford no longer services this part. One dealer I called said they didn't even have a way to look it up. Another, more accomodating dealer took my number and called me back after looking it up on microfiche. I was told Ford discontinued this part in 2000, but he gave me a part number to search the internet with.
As for the repro, of the 2 that NPD sells I have the more expensive one with the brass float. I will be sending it back. The most obvious difference compared to the original is the pick up tube points in the wrong direction. On the original part, where the tube comes thru the sealing plate it makes a 90* bend with the tip pointing at the 10 o'clock position, aimed right where the fuel line comes off the frame rail. On the repro this tube is pointed at the 2 o'clock position and is just barely to the right of the gauge sender terminal. I was able to squeeze the weather boot passed the tube to get it on the terminal, but it was pressed right up to the tube so there's no way to get a rubber fuel line over the tip and no amount of trimming will fix that without completely removing the boot. I'm sure I could get it to work, I'd just have to remove the boot to hook up the gauge wiring to the sender then put a gob of RTV over the terminals to keep water out, then replace the rubber line with a longer one to reach up and bend over to fit over the pickup tube which would be pointed away from the metal fuel line instead of aimed at it like the original part does. If I were looking for the cheapest way to get this done I would consider it, but I want to keep the original rubber boot over the terminal which means there's no way this part will work. I did find a shop in CA that has a new original part for $175, but I'm hoping a call I made to find a good used part will pan out.
