ive seen it said time and time again that you need an h pipe with hipo manifolds. my question is why? couldn't you run them with a straight dual exhaust? im not looking for a manifold vs headers vs whatever debate, just wanting to learn more.
Correctso you could run the manifolds without a crossover but would lose out on some performance?
To clarify more-- regular manifold,hipo or headers ,does not matter which. Run exhaust with or without H/x pipe.ive seen it said time and time again that you need an h pipe with hipo manifolds. my question is why? couldn't you run them with a straight dual exhaust? im not looking for a manifold vs headers vs whatever debate, just wanting to learn more.
Ironic, because there's no gain from stock hipo manifolds anyway.....so you could run the manifolds without a crossover but would lose out on some performance?
You don't NEED one but it's there for a reason. Remember, Henry didn't spend any extra when it wasn't needed.ive seen it said time and time again that you need an h pipe with hipo manifolds. my question is why? couldn't you run them with a straight dual exhaust? im not looking for a manifold vs headers vs whatever debate, just wanting to learn more.
The H pipe will also on getting rid of that drone that some exhaust systems have.ive seen it said time and time again that you need an h pipe with hipo manifolds. my question is why? couldn't you run them with a straight dual exhaust? im not looking for a manifold vs headers vs whatever debate, just wanting to learn more.
Mellows the tone a little and increases torque in my experience. It should since it effectively doubles adds a pipe to each pulse…so you could run the manifolds without a crossover but would lose out on some performance?
Yes, but life is more fun if you keep believing that they do 😁Ironic, because there's no gain from stock hipo manifolds anyway.....
Searching for dyno testing of crossover, I only see people reporting on sound. Does anyone have link showing actual HP/TQ gains?
I plan to install one to tone down the noise but I'm a little skeptical that they do anything for HP/TQ unless you have long tube headers and the crossover is placed right at the collector.
Engine Masters on Motortrend tested them against each other on a dyno in Episode 22. The result was 5-6 lb/ft more torque in lower RPMs for both H and X pipe over straight dual exhaust. Very minimal gains anywhere else.Searching for dyno testing of crossover, I only see people reporting on sound. Does anyone have link showing actual HP/TQ gains?
