Got the 'stang out of winter storage today and one of my problems from last year is still with me so I'm going to try & fix it. About every 5th time or so I go to crank the car the starter motor turns over incredibly slow, like its being held back by something. When it happens I may have to hold the key in the start position for 20 seconds or so just to keep it turning & hoping it might fire. Most of the time it turns over fast & fires right up. I don't think this is a battery related issue, it had a battery with a fresh charge in it. Any ideas?
Bad connection, but i'd test the battery too. And is this after it's been driven a bit? Because then it could be heat soaked.
I used to have that problem with my coupe. The problem was usually when I had driven for a while, and the starter was hot, like Johnny K said above.
My connections were fine, and the battery was fine as well, holding a charge perfectly.
Replaced the starter with a rebuilt unit and never looked back. If you check your connections and find nothing wrong, I'd suggest something like that.
only time ive had this problem on a ford the problem turned out to be a dirty ground connection and would only happen after engine was warm,would have to let it cool for about 10 minutes for it to crank fast enough to start engine. wes
I changed from the stock battery cables to 2 gauge cables (Auto Zone) and it really helped.
Maybe it is just tired some days? Just kidding replace the starter if your battery and connections are fine and you will be ok then.
Al
