all of my other guages work except my fuel and temp. i ran the motor until it was hot and the temp didn't move. i have about at least a quarter tank of gas and it shows below empty. i squeezed the connector ends on the temp sensor on intake and fuel sensor on tank in order to get a better connection. still didn't work. where should i look next?
I had the same problem.... Pull your gauge cover off and take out the cluster. My guess is that the plug, that goes into the gauges has a connection that isn't tight. Those plastic copper covered connections can come loose, thus not giving current to the gauge. This recently happened to me and once I took it out and looked at it, I got it back to normal with little effort.
Hope it helps.
Tom
