I have a rebuilt wide ratio toploader I will consider swapping for someone with a close ratio unit. It's an tagged "RUG-AV" which means it came in a "1970 Mustang 302,351 with wide ratio". It will fit any smallblock Ford application. if you need more info on toploaders see this page.
If you drive on the street or strip, you NEED a wide ratio unit, I don't,.. so I need a close ratio. I'm either going to convert it to a close ratio or swap someone so I thought I'd ask first. It's for a smallblock and I used it in my 66' several years ago. It had the top ear on the driverside welded on by someone many years ago. They did a good job, it's sound and worked for me no problem. You can see the weld but it's on the top and hard to see when it's in the car.
Anyone wanna' swap me? ::
