1 - 2 of 2 Posts
and will it bolt right in or what kind of adjustments or modifications would I have too make. I did a search but it really didnt answer my questions.
It depends on what motor you have. If you have the 5 bolt bellhousing on a 289 It wont fit the back of your motor. If you have the later bell housing pattern than you will be ok. You will have to get a flywheel for the aod torque converter bolt pattern, a TV linkage kit, a crossmember for the aod, and shifter linkage. Its my understanding that it will be a tight fit in the tunnel but will work ok. Windsor-Fox has some good info on the swap.
1 - 2 of 2 Posts
