1 - 11 of 11 Posts
I am looking at a used wiring harness for my 67 Fastback that has the tach and fog light hookups. Will this harness work on my non-tach/non-fog light 67?
That thing would be worth some bucks. I would buy it and flip it if the price is right.
I had a tach cluster originally and the PO took it out when he sold the car. The standard gauges are working so it must be able to be done.
I have purchased a Tach cluster and hope to get it wired back in once I get my new engine. Of all of the projects I am doing this one scares me the most.
So will it work?
I can not think of Why Not.
These are just accessories. I do not believe they control the output to anything else.
Of couse I am basing this statement off of the 66 diagram.
It will not work on the 69/70 without repinning the connector into the printed circuit, as the layout of the pins within the connector differs between the tach and non-tach underdash harness. Just passing this one along for those 69-70 owners who might think what works for 67/68 would work for them.
good luck.
Sorry about that, thanks Justin.
You need to connect the two tach leads together or it won't run. Easy to do as one is female and the other male.
1967 Mustang GT fastback
I agree - it's a piece of cake to get the engine to run- as said previously just conect the male and female tach leads, that makes the series circuit with the ignition complete and away you go. As far as the idiot lights-back-to-gauges, the oil sender needs to be switched (cheap fix) and the ammeter circuit connected. Not really difficult to do. Easier to go from tach to non-tach than the other way around - also you can make a LOT of money by flipping the tach unit if you wish to go to the oil/amp gauge layout.
Discussion Starter #11
I didn't win the auction, my top bid was $311.00. Hope the seller has a Merry Christmas! Hehe!
1 - 11 of 11 Posts
