1 - 10 of 10 Posts
· Registered
1966 Mustang 200ci
I’ve been working on putting in the door glass in my 66 mustang and the drivers side is perfect fit, rear quarter, door glass, and vent all fantastic. The passenger side not so much. I cannot seem to get it right, the rear quarter window is aligned but the door glass seems to not sit right. It’s like the very top corner doesn’t roll up high enough and it gets caught on the rear quarter window. I’ve ran through the adjustments and I can’t figure out which one would fix that. I’ve looked through a TON of adjustment videos and I can’t figure this one out. Any help?
· Registered
1966 Mustang 200ci
Discussion Starter · #5 ·
Make sure your door window is fully engaged in the forward window channel. If it's not fully seated, the window will sit too far toward the rear.
I thought I had it on the track. It rolls up and down fine, this job is such a pain. There is a small gap at the vent window and the main glass at the very top so it’s obviously rolling back but I can’t figure out why.
· Premium Member
Make sure the door is lined up first. Take the vent window frame out, line the main and quarter window up, then fit the vent window frame.
Reactions: ChaseC
· Registered
1965 Ford Mustang fastback T5 Ncas 9in Locker
Check here.. lots of good info ..April 7&8 2009 window/vent adj. Thecareandfeedingofponiesblogspot.com. Happy reading.. hope this helps.
1 - 10 of 10 Posts
