anyone know where I can buy a new one for the 65 coupe?
Randy
65 pony from ground up, inline 6 (son's car),
66 Red Convertible, 289(dad's car)
The wiper motor wiring is integrated into the main underdash harness. Is that what you mean, or the wire that goes to the washer pump?
65 Mustang Convertible 289 C-code
Ivy Green with Ivy Gold & White Deluxe Interior
http://albums.photopoint.com/j/View?u=1571514&a=11942607&p=42928766.jpg
Actually, the wiper harness is seperable from the main loom. The only way it connects to the main loom is via a bullet conenctor that provides switched 12Vdc from the ignition switch/fusebox. As far as your question goes, I would check National Parts Depot, restoremustangs.com and other local shops. That harness isn't that complicated, so you could rebuild it if you've got the connectors for the wipe switch and motor.
Good luck...
http://albums.photopoint.com/j/View?u=1571478&a=11942550&p=43703435.jpg
Discussion Starter · #4 ·
you are correct, it is separate on a 65. the end connectors on mine are what disintigrated.....
i will check with npd....rm didn't have them....
thanks
