1 - 18 of 18 Posts
Starting to think about the wiring process and was wondering what type of loom is best and affordable. I prefer not to use the convoluted split plastic stuff. I'm using the AAW harness.
Well, you could always use wiring harness tape, as Ford did. It's not electrical tape, as it has no glue to seep out.
I used WireCare's F6 woven wire loom. Its easy to use and looks nice. Its tough as nails and pretty easy to use. I also have AAW and wrapped all of it. I think I used 3 different sizes. U can cut it with a hot knife (use a torch to heat a razor blade and one swipe and its done) I just bought more for any future wiring projects because I liked it so much. 1/8 is for single wires, 3/16 is for about 2 or three if they are small, the main harness I think I used 5/8. You can also use a small piece of shrink wrap at the end of the loom and onto your wire connector for an absolutely beautiful result. I would definetly recommend
Any pics?
Not with me. I can try to shoot a pic of the loom but IDK if it will show up well- probably the loom itself would show- I will try to get pics tonight- Their website has pics of the material (oh i used black btw but they have a bunch of colors and patterns)
I used WireCare's F6 woven wire loom. Its easy to use and looks nice. Its tough as nails and pretty easy to use. I also have AAW and wrapped all of it. I think I used 3 different sizes. U can cut it with a hot knife (use a torch to heat a razor blade and one swipe and its done) I just bought more for any future wiring projects because I liked it so much. 1/8 is for single wires, 3/16 is for about 2 or three if they are small, the main harness I think I used 5/8. You can also use a small piece of shrink wrap at the end of the loom and onto your wire connector for an absolutely beautiful result. I would definitely recommend
Do you recall about how much of each length you bought?
about 20 feet of the 5/8- then about 50 of 3/16 and 1/8 (but I covered everything- even all the way to the horns, under dash- everything was covered. I think I am gonna be a little short on the 1/8 so thats why I ordered more (I got 50 more feet so I could use for ATV/Trailer wiring etc)
+1 I have the AAW harness from front to rear and covered everything with just about the same amounts with a little left over.
I used Techflex F6 which I think is what you said you do not want to use. The trick I learned mid way is to cut it with a hot knife or in my case I heated a 1.5" scraper blade with a torch red hot. This seals the ends so it does not fray. I also used various round tools/pipes to burn holes for junctions. I love the way it came out. I also used cloth harness tape as underwrap at the "Y's".
I used 1", 3/4", 1/2", 3/8", 1/4", and 1/8" for various areas to do under dash, engine bay and trunk area. I had a lot of custom wiring and used a lot of this stuff. I dismissed the 1/8" at first as being too small, but it is fantastic to wrap a single wire or a couple smaller wires
Edit: Here is what I used. Have some left, but could have used more 1/2" and I am totally out of 1/4". If I had it to do over I would have used a lot more 1/8" under the dash so would have bought 50'
1/8" 25
1/4" 50
3/8" 50
1/2" 10
3/4" 20
1" 10
I think OP said he didn't want the "walmart" kind (the funkyhard plastic ribbed) kind that never closes right and wires fall out and looks like a 5 y/o wired it up)- or that was my interp- so if this led us down the wrong road- my bad
I also used TechFlex with my AAW harness. Easy to use and looks great. I bought some 1” and didn’t use any of it. Mostly used 3/4”, 3/8”, 1/4” and 1/8”.
Timely discussion.
I ordered some power braid and harness tape to try.
Holley makes some too.
Some came with my sniper and I order some extra.
I’ll try the hot knife next time too.
Thanks guys.
The power braid came in.
Looks just like the Holley stuff to me.
One of the two Probably just rebranded...
I also used the tech flex split loom for my AAW install, got it direct from the guy that sells on eBay - discounted enough to cover shipping costs. I put heat shrink around most of the ends, too.
Here's what I used:
3/4" 6 ft
1/2" 19 ft
3/8" 32 ft
1/4" 38 ft
The 1/4 may be a little high because since I had it I used it for the rear speaker wires, probably a total of 15-18 feet just for them.
1 - 18 of 18 Posts
