Okay, now that I've been set straight on finding a wiring schematic for hooking up the Duraspark to the MSD, I've got two more questions...
1. How is the distributor getting advance? The vaccuum advance isn't hooked up. Sooo, does the MSD box give it electronic advance? Does the Duraspark also have mechanical advance?
2. How do I connect to the horshoe shaped coil connector if I don't have it? Since this is a transplanted distributor, this piece was left off from the donor car. Can I simply omit this connection?
If there are any doubt as to what I'm talking about, check here: http://www.msdignition.com/pdf/pdf17.pdf
