I have my 72 parts car totally stripped out cept for 1 thing... yeah the underdash harness.
It is totally disconnected everywhere except for the point where it comes from the firewall.
There is a rubber cone or plastic(pretty tough) anyway how does this disconnect or do i have to cut that SOB?
I read the post below about the 66 wiring, and the reply about the engine and rear assembly's were cake to disconnect.
The plug should come out from the inside to the firewall. It should push out. You must remember, it has been stuck in there for years...
What engine did you finally deceide to use in the Mach 1?
I picked up a Cleveland block from a guy in CA
due to the expenses of swapping out a 429, bigblock c6 and little things like hunting down brackets etc.
I had some serious sense talked into me i guess you could say?
Plus I have my 4bbl closed chamber heads for the cleveland waiting to be used.
On the Cleveland forum, I have gotten some nice build info to use. Those guys also know their stuff very well **PROPS!!!!**
~Wayde
