1 - 2 of 2 Posts
I will be splicing my EFI wiring harness into my original harness tonight. Since this is my first time reading a wiring schematic, I would like to double check with you guys before I do anything.
Here are the connections I need to find on my original system:
12V Crank only
12V Crank and Run
12V Run only
I was planning on splicing these connections in near the starter relay as follows:
12V Crank Only - Red /Blue Stripe (Connects to "S" post on starter relay)
12V Crank and Run - Red / Green Stripe (connects to ignition coil)
12V Run Only - ??? I'm not sure which wire to use for this.
Please let me know if any of these are incorrect, or if there is a better way to do this.
TIA!
The crank wire should be fine but I don't know if you want to use the coil wire for crank/run because it may be a resistance wire. I spliced mine in right off the ignition switch for this reason.
As far as the run only wire, there is no such thing on the ignition switch so just hook it to the crank/run one also. The only thing this controls on the EFI is the 02 sensor heater elements and they don't draw enough to effect starting the car.
68Restoman
http://memimage.cardomain.com/member_img_a/519500_18_full.jpg
1 - 2 of 2 Posts
