71 Mach 1 351, I have the wiring and plug (male end) that is attached to the a/c clutch control fly wheel, but at one time someone cut off the wires at the wiring bundle (down by the radiator support) and removed the female end of the connector. thanks
The power for the A/C clutch comes through the plug at the rear of the engine. It's just a short wire, @ 12" long....
thanks, I note such a wire that was circled and tied to shock tower support. It has a frayed end with no connecter, and I have yet to note where it goes (for certain ). If this indeed the wire that I am looking for I still need a female connector for it. many thanks keith
The wire you are looking for is black with yellow stripped.it plugs into the harness where the engine feed wires plug into It was origanaly taped in the gauge harness.FastE
