1 - 11 of 11 Posts
Wanting to buy front disc brake setup for a 1966 Mustang with a 6 cylinder.
I don't care if it is 4 bolt or 5 bolt rotors. Closer to N IL the better.
I have a set of original Ford disc brake spindles with brackets, 5 lug, for $275. You can buy the rotors and calipers on ebay or autozone.
It would be $25 to ship them to you. They have been cleaned and check for straightness.
I can send a picture to your email address. Bob
Cheap and Brake
System, don’t belong in the same sentence.
If you must combine the two, Scarebird is your answer, never me!
I have a pair of Kelsey Hayes four piston calipers from 65/66 Mustang. THESE ARE CORES. Hard work is done- pistons are out of the bores. Bores look good. It will take about $250 for parts. The nice thing about original parts is they will fit.
Anytime when i'm at work and someone wants to cheap out on brakes ,my response is usually something along the lines of--- "It will cost you more than that when you hit me" OR "the ambulance ride will be more than that"
As noted by others.
Brake setup should be considered as special, not when on special.
A quality braking system saves you when you need to make a hard stop Imho.
1 - 11 of 11 Posts
