I'm looking for an OE shifter and linkage for a 4 spd toploader. I'm in the market for a toploader for my 70 FB and based on what I see on CL and Ebay, most units are w/out shifter and linkage. I am expecting it to take some time to find a toploader at the right price so I might as well look for the linkage and shifter. Feel free to PM me.
Thanks, Tom
Discussion Starter #2
After doing some additional research I believe the 70 would have come with a Hurst shifter from the factory.
Tom, I have an original shifter and linkage from a 68 Torino big block car. I am unsure if is what you may be looking for or if it it might satisfy your search. Let me know if you would like pic's or if you have any questions. Thanks, Robert
Hi Robert, thanks for the note -sorry for the delayed response I haven't checked this site in a few weeks. I appreciate the offer. I did end up buying a complete unit with shifter, linkage and trans. I think it's a close ratio so I will try it out and may swap for a wide ratio. Thanks, Tom
Just in case you don't know, input shaft length can be different between close and wide ratio Toploader. Make sure the pilot bearing is correct or input shaft shoulder is shortened. I don't remember the details of this.
Not true.
Input length is identicle on all close / wide ratios , output is the same as well.
the difference between close and wide are the internal gears
