Hi Friends
I have been searching for months on my garage queen for a bad lifter sound or exhaust leak. SHop vacs tests, soapy water sprays and finally the only thing that worked was a good old Oven MITT on a cold start engine. I was throttling header pipe surfaces with the mitt when ........
I can believe what i found, So help me understand !
I have a hole that was used to mount my Transmission tube. Its was plugged which never amounts teh tube flange because its too big for the tube flange hole. So I could never find the right adapter, So i got lazy and left this off ..It just a mounting point. right ! WRONG ! I cant get my eyes back there and when probing I find the large hole is pumping out air on a idling engine. WTF! these are not smog heads so why is this hole open?
I have been struggling with 10 MPG prb;ems, Ive changed carbs, just finished a valve lash adjust and ..........can this really cause 10 MPG..loss, The push is gentile garden hose strong but i can seal it with my finger no problem.
the smaller threaded hole below the freeze plug is burned but not pumping air.
What is this !
What is this !
