1 - 1 of 1 Posts
64-66 Swap Meet Clearance
AUTOMATIC TRANS. LEVER USED- 64-68 $10
BODY PLUG KIT – 32PC KIT 65-66 $25
BUMPER BRACKET OUTER – LH – NEW 64-66 $7.95
BUMPER GUARDS – REAR 65-66 $26 PR
BUMPER GUARDS USED – PR 65-66 $10 PR
COIL SPRING INSULATOR – PR $5
CONSOLE ASHTRAY LID – 64-66 $22
CONSOLE PLATE LONG 65-66 $85
CONSOLE SHIFT PLATE AUTO – 65-66 $39.95
DISTRIBUTOR CAP – 64-73 $5
DOOR HANDLES EXTERIOR PR 64-66 69-70 $22.50
DOOR HINGE PIN AND BUSHING KIT $2.50EA
(INCLUDES 1 PIN AND 2 BUSHINGS)
DOOR HINGES LOWER USED – 65-66 $10 PR
DOOR WEATHERSTRIP – PR 65-66 $13.00 PR
FENDERS USED 65-66 $150.00
FLOOR PAN – COMPLETE 64-70 CP/FB $399
FLOOR TO FIREWALL EXT. 64-68 $26
FUEL FILLER PIPE GASKET $1.50
GAUGE CLUSTER GT USED 65-66 $20
GAUGE CLUSTER USED 65-66 $35
GLOVE BOX DOOR USED 65 $15
GRILL BARS USED – 65-66 $20PR
HEATER CONTROL USED – 65-66 $20
HOOD SCOOP SHELBY STYLE 65-66 $85
HOOD TO COWL SEAL WEATHERSTRIP 65-66 $5.50
HOOD USED – 65-66 $60
LOWER BALL JOINT – 65-66 NEW $22.95
OIL SENDING UNIT FOR LAMPS 64 EARLY 65 $7.50
OUTSIDE DOOR HANDLES 65-66 $22.50
PERTRONIX UNIT $55
PONY DOOR HANDLE SHAFT RH 65-66 $13.00
POWER STEERING HOSE – SHORT 64-68 $12.95EA
POWER STEERING LOWERING BRACKET 64-70 $14
QUARTER EXT. USED 65-66 $20
RADIO BEZEL REPAIR PANEL – 65-66 $13
RALLY PAC REPAIR WIRE 64-66 $23.95
REAR WINDOW WEATHERSTRIP CP – 64-68 $16.00
SLAVE CYLINER LOWER BRACKET – NEW 64-70 $14.00
SPLASH SHIELDS NOS 65-66 $30
STRUT ROD BUSHING SET 65-66 $22
SWAY BAR BUSHING KIT 5/8” $11
SWAY BAR END LINK – PR 64-70
TIE ROD INNER – RH V8 64-66 $25
TIE ROD OUTER $25
TRUNK BRACE CAP RH/LH CONV 64-70
TRUNK HINGES CP/CV $20
TRUNK LID SPRINGS CP/CV USED – 65-66 $30
TRUNK WEATHERSTRIP – CP/CV 64-70 $8.50
TRUNK WEATHERSTRIP FB – 65-66 $8.50
TURN SIGNAL FLASHER 64-70 $2.50
TURN SIGNAL WIRING 65-66 W/ALTERNATOR $22
U JOINT 289 65-67
UJOINT BOLT – PR – 64-73
VALVE COVER SET USED 289 $40.00SET
WHEEL COVERS USED – 66 $75 SET $25EA
WINDOW HANDLES PR – 65-67 $9.50
WINDOW REGULATOR LH 64-68 $19.95EA
WINDOW REGULATOR RH 64-68 $19.95EA
LH/RH WINDOW REGULATOR PAIR $30.00
FAN SHROUD BRACKET 3 ROW $13.00
HOG RING W/PLIERS $18.95
INTERIOR DOOR HANDLE – RH $8.95
DOOR HANDLES INTERIOR 65-67 $8.95
FENDER EMBLEM 289
RUNNING HORSE PLAIN PIN ON 64-68
QUARTER TRIM UPHOLSTERY CP-BLK $27.00
TRUNK FLOOR PR 64-70
UPPER CONTROL ARMS 65-66
FRONT VALANCE $29.95 64-68
REAR VALANCE GT 64-68 $29.95
FLOOR TO FIREALL EXT. $28.50
TRUNK MAT 64-68 $17.00
For Personal Friendly service call Deb or John to place an order at 814-838-8153.
Questions? call or e-mail [email protected]
Pennsylvania Pony Parts
1 - 1 of 1 Posts
