Hi all,
I'm planning some winter projects - this time cheaper than my previous idea of upgrading my engine. :crying:
So my idea is to convert my tail lights to LEDs - I'd also like to do it myself and not just go the normal route of buying the SD kit.
Living over here in Europe I'd really like to have some yellow turn signals at the back like there are on the front.
So my question is, has anyone tried yellow leds behind the stock red lenses?
I don't know how yellow they would actually be once the work.
What I'm planning is to run a new wire from the stop light switch so that I can isolate that from the turn signals - the running lights would power red LEDs via one resistor, the stop light switch would bypass the running light resistor and pass through a smaller resistor - that would give me the different light intensity when braking.
Finally I'd like to add some yellow LEDs in the middle of the red LEDs that would come on when the turn signal is activated.
Don't know if it would work - I've never done anything like this before but I think it should - if the yellow is strong enough.
Thanks for your thoughts
