1 - 10 of 10 Posts
Z's 1965-66 low profile street-competition engine crossmember
Low profile crossmember. Will provide an additional one inch of ground clearance vs. our original crossmember, nice for cars that have been lowered. Made of the same high quality materials. 100% USA steel and USA manufactured.
$199.99 base model
$229.99. With integral jackpad
comparison to my previous std. crossmember:
This design was pioneered by Ford in 1969 for the Boss 302 program as a low cost fix for flexing at the LCA. It improves on the '65 & '66 stock engine crossmember by tying into the lower control arm mounting points, resulting in improved rigidity for the unibody lower front frame section. Helps to stiffen the car right at the control arms where it's needed most. Perfect for cars that already have an export brace and Monte Carlo Bar. Every '65-'66 Mustang will benefit from this racing front crossmember. Guaranteed to improve steering stability at all speeds.
Substantially superior to similar looking cross members currently sold today.
Features:
1) No interference issues with oil pan.
2) Will clear oil pan if using Ron Morris lowering engine mounts. Other cross members will not clear
3) Made from 1.5" steel tubing, same diameter as the stock Ford crossmember, only thicker. Other are relying on smaller 1.375" tubing, or even worse, 1.25" tubing.
4) Steel tubing thickness: 0.125", stronger than the stock and other aftermarket cross members. Others are using thinner tubing and/or smaller diameter tubing.
5) USA made with USA steel
6) Complete with grade 8 bolts & hardened washers (USA made).
7) priced under the similar competition.
8. 100% money back if not satisfied (not including return shipping)
sold over 400 to Mustang forum members, excellent reviews. 100% satisfaction.
reviews, newest to oldest:
http://forums.vintage-mustang.com/vintage-mustang-forum/1115794-zray-s-crossmember.html
http://forums.vintage-mustang.com/vintage-mustang-forum/1037058-zray-cross-member-review.html
http://forums.vintage-mustang.com/vintage-mustang-forum/793033-competition-engine-crossmember-review.html
email [email protected]
Priced less than other Boss 302 type crossmembers sold, as well as beefier and better fitting. Unlike most, my crossmembers will fit engines that have been lowered 1/2" with the Ron Morris engine mounts). Will fit most aftermarket oil pans too, such as the vintage Cobra lettered T pan, Avaid road racing pans, Moroso pans, and most Canton oil pan applications.
larger diameter tubing than many other aftermarket crossmembers, optional model has a round 3.5" diameter jackpad made of 0.25" thick steel tread plate that will fit your floor jack perfectly,
These same crossmembers are also available thru Opentracker or eBay for your convenience
$24.00 Flat rate shipping to the continental USA
email [email protected] to order, or for any questions.
Z
Discussion Starter #2 (Edited)
a heads up
just a heads up, the last powder-coat shop in my vicinity is closing down.
The last crossmembers I have with powder-coating are:
Three 65/66 crossmembers without jack pads, and one 65/66 crossmember with the jackpad.
After those are gone, the crossmembers will ship "bare steel", buyers can then paint or powder coat as desired. The bare steel crossmembers will be priced $10 less.
Z
NOTE:
all '65/'66 powder-coated crossmembers have been sold. New orders will be shipped "bare steel". New pricing as follows (reflects $10 off the previous price of the powder-coated crossmembers) :
$189.95 base model
$219.95 With integral jackpad
Z
Anyone know what it would realistically cost to have one of these powder coated?
I paid $10 to have them powder-coated. That wasn't a bulk price, just regular retail. I imagine the cost would depend on whether the powder-coat shops in your area have much competition.
Z
Looks good!
:eek:)
Tony K.
Z
Down in FL three trim pieces cost $100 to powder coat.
Discussion Starter #8
Florida real estate is likely 10X more expensive too. I agree that my state, Oklahoma, is a lousy place to live, for example it's too crowded (the DFW metroplex has a higher population than my whole state), the fishing, hunting, and twisty back roads all suck. Cost of living is way too low, and whether a people belongs to the Republican or Democratic party, we all pretty much adhere to the party of "Live and let live".
Don't anyone move here.
Please
Z.
Heya Z! Do you know if your crossmember will clear the Cobra T-pan WITH the RM lowering mounts? ya know, before I pull the trigger on the pan ;)
Also, I'll need one soon with a jackpad for the rust bucket project...
Discussion Starter #10 (Edited)
I know it will clear the original Cobra lettered T pan w/ the Ron Morris 1/2" lowering engine mounts. AFAIK, the reproduction pans have the same dimensions.
Z
PS. If you you have clearance issues, which I doubt, I can make you a custom bent crossmember at no extra charge besides shipping .
1 - 10 of 10 Posts
