I have a 1967 S Code that will not shift into reverse. All other gears are fine, just reverse. Is this a linkage alignment issue? If so, how do I resolve? Thanks in advance.
If you haven't yet do so, revisit the linkage setup. Have your tried going into first then reverse. They are on the same shaft. This is, especially, helpful when idling to prevent clashing?
No i just brought home on the trailer from the restoration shop and it wouldn't go into reverse to back off the trailer. A friend crawled under and said it was a linkage issue, that it needed to be aligned. If this is the case, I 'm not sure what that process is. Thanks
Put the shifter in N, have your buddy hold the clutch pedal down and go underneath with a 1/2" and a 9/16" wrench and see if you can move the R shift lever on the side of the case by turning the nut that holds the shift lever onto the transmission.
Surely you can find the adjustment procedure for the Comp Plus shifter on Hurst's website.
Look at at the side of the shifter. there is a quarter inch whole that goes thru the shifter mechanism. Unhook all the rods from both ends( shifter and tranny) . Slide a 1/4"drill bit through the hole in the shifter, this will lock it in neutral position. Make sure all the arms on the tranny are in the neutral position and adjust the rods to fit without moving any other linkage. It won't go in reverse until everything else is in line. just did mine. piece of cake!.
Related Threads
Vintage Mustang Forums
posts
4.2M
members
101K
Since
2001
