The question I have is, can one look at the instrument wire harness connector for the instrument cluster and determine if the wire harness is configured originally with a factory Tach or not?
Background, recently obtained Mach 1, at least third owner, was given an extra cluster panel with tach that I was told was in car when seller picked up the fastback. Existing cluster panel did not basically work (some wiring throughout car not hooked up such as wipers and heater or just missing....)
My plan is build new cluster from scratch, have new deluxe woodgrain bezel now just need to determine is my wiring harness for a factory tach or not.
Marti report did not specify any info for my VIN.
Second owner also installed a MSD distributor which may also alter things as well and had a dash mount speed shift light and tach which I have removed.
Guidance on determining wire harness is for Tach or not, is greatly appreciated or where I can research for an answer. I have Ford Shop Manuals for 1969 which are hard for me to decipher details for Mustang builds
