Hi All,
I purchased a set of Daniel Carpenter gaskets for my rear side markers and have a question regarding the larger seal. The location of the smaller seal is straight forward, which goes between the red lens and chrome trim/housing. As for the larger seal, is it suppose to be installed on the exterior or interior?
I installed the seal on the exterior (placed between the chrome trim and quarter panel) and it looks funky. Is this the correct? The seal is made from a foam material and am concerned it will deteriorate over time.
If I install the seal inside the quarter panel, it does not seal the light and my problem persist with water getting into my quarter panels.
I searched online and even called Daniel Carpenter and was not able to get an answer. I looked through google photos of other cars and cannot see a gaskets around the light trims.
I attached pictures for reference. Any help is appreciated.
