Hello,
Still fine tuning my 289 rebuild, took the intake off to reseal it. I noticed that the heads I used, has some pitting on the head to intake surfaces. I am installing the standard Fel Pro gaskets, which the instructions state to install dry.
Does this pitting need to be addressed? Will it cause any issues? Thoughts of using Permetex aviation sealant on the intake gaskets on the head side only? I estimate the dept of the pitting at .005, and the worst is in the pic, all other surfaces are very minor to none.
I could not tune the 4100 1.08 properly that I used, it is/was running RICH with stock jets and correct venturies per the manual. The right side mixture screw pretty much had no effect adjusting the metering needle in or out. While the left side if I went all the way in, the engine would stumble like it should. Most likley the head/intake and carb issues are not related? I could not find a vacuum leak on the intake, other than a possibly leak on the aft right. I say that, since the car was running so rich, cab cleaner woud not make the RPM increase, it would decrease slightly when sprayed on the aft right.
To rule out the carb, bought a Summit 2008 series to try once I get things back together.
