I have a '70 Mach 1 w/a 351C 2 bl autolite 2100. The car will not idle when it gets to operating temperature. The car will run fine once you get to freeway speeds, but it will not idle or allow you to apply the brake and come to a stop without dying. I have put on a rebuilt 2100 and the same problem exists exactly with that carb. The car will even die as soon as it gets to normal operating temperature if you start it up and let it idle for a few minutes. It does idle when the idle is working with the choke on and the engine at a cool start up temperature. I have plugged all vacuum lines except the transmission(FMX) and the power brake line so I don't think it is a vacuum problem.
Help, where else do I check.
