428 engine stopped rotating. Afraid to force it.
7K views 59 replies 29 participants last post by  Gopher428
Remove the rocker shafts and try again. If it still binds, add a couple ounces of ATF to each cylinder, let sit overnight, then try again. Do NOT put the plugs back in until all excess oil has been purged from the cylinders, the rocker shafts reinstalled and the valve lash adjusted.
