67 and 68 dash pad......Can they be fixed?
2.3K views 4 replies 5 participants last post by  CR67
The dash pad on the 68' is slightly warped and the driver's side mount has separated. You can see it in the picture below. I just received a repro. dash pad and it's more like rubber. The grain on top is too heavy also. The original has a smoother vinyl feel. Is there anything I can do to some how straighten my original and repair the mount? Has anyone done this? Should I just keep my original or install the repop?
Thanks, http://memimage.cardomain.net/member_images/4/web/544000-544999/544570_27_full.jpg
I too have a dash pad that sags. It's off the car now and I plan on making sheet metal stiffeners to slide inside where the dash brackets go. I think (hope) that will greatly help.
I believe they sag because the cavity inside the pad is too large. Add a little heat and droop it goes....
I decided just go with the repop even though I didn't care for the different texture. There was no way I could ever make the old sagging dash pad as straight as the repop and afterwards I was very happy with it. So I say replace it. Just my 2 cents.
My finished dash except for thw white face guage overlays.
There are shops that restore them, but here the one I found could not do the 67/68 due to some factor of the design being too hard to emulate/repair.... it was expensive for other years. I redyed my 'verts, it was in OK shape, went repro for the coupe, have not installed it yet.
