just as a followup on my Classic Auto Air Daily Driver install. I used the video I posted above as a directional guide, here are the highlights and problems:
1. The inside unit I was able to install using existing holes in the dash, but I did have to drill alternate holes on the braces that attach to the dash in order to use those holes. Outside of working under the dash, all of that went well ( I did have the seats out for easier access, but probably not required) Drilling the two drain hose holes into the floor (on the transmission hump) was a bit difficult just due to location and I had already installed the system. If I had to do it again, I would fit the blower, mark where the holes needed to be, then take it out, then drill the holes.
2. The holes needed in the firewall were a PITA to drill since you don't have a direct shot at them with the valve cover location. I used a metal hole saw, and I guess the tip of the day is, go very, very slow, or the drill will be jerked out of your hand if you get to big of a bite since its at an angle.
3. The installation of the new crank pulley was a bit difficult not because of anything other than how hard it is to get to the fan bolts to remove it. My old crank had three belt grooves, two were being used for the alternator and the third in the same location as the new crank pulley but unused.. It would of been nice to just use it rather than replacing a crank pulley for one that is 1" less in diameter.
4. The documentation is lacking in regards to installation of the compressor. Essentially it is a drawing of how it is installed, which includes a lot of spacers to get it lined up properly. It wasn't hard, but no step by step on how to do it.
5. On the topic of the compressor installation, I unfortunately attempted to loosen the wrong bolt on the water pump (because I had a drawing only and thought I knew which one it was), and it twisted off. I posted a question here on the forum on my plan forward and everyone said to replace the water pump. That part was a good call as the water pump was very rusty, but unfortunately the bolt that broke did not have enough protruding to remove easily. After attempting an easy out, which would not budge the frozen bolt, I ended up retapping directly into the same bolt and it ended up going better than I thought. I don't think that bolt was ever coming out. My other option was to pull the timing cover which I really didn't want to do. The rest of the bolts came out okay, but one would not re-tighten, so I used a helicoil to get that one to tighten. I guess the lesson learned here is use anti-sieze compound if you don't want to have to do something like this.
6. The condenser and drier installed in front of the radiator was not to bad install but I already had most of grill off already. There were two dimples to drill the holes, one from the inside and one from the outside, and using those it fit perfectly. The pressure switch installation documentation was sketchy, but I figured it out. Pressure switch installs next to the drier, two wires go through the firewall, one to the compressor, one to the blower.
7. I installed the R134A refrigerant myself, and that went okay, but could of used a better gauge/hose system than the cheapie I bought. I rented a vacuum unit from Autozone and let it run overnight (the manual recommend minimum of 45 minutes).
8. I put clamps on the drain hose lines, as they leaked a bit inside the car.
9. I ended up calling support on the refrigerant tape that they provided but gave no explanation on where it went. It goes on the #10 line (i.e. the bigger line coming out of the blower) to prevent condensation build-up during operation.
Overall, this was not difficult to install, just time consuming, and a bit frustrating because of breaking the wrong water pump bolt. That will probably be a blessing in disguise that I don't know about.
I haven't been able to test it out on the road as I have a few weeks of other installation work to do before my car is drive-able, but it does blow very cold. I ran it two different times for about 30 minutes and it worked great.
On a final note, as a retired mechanical engineer, I wish I could sit down and discuss the design of the fan bolts along with the inside bolt on the thermostat housing. Someone with a lot smaller hands than me thought that would work well I guess
Hope this helps someone on future installs, I included a few photos of it installed.
Blake
