Alternator Not Charging?!?
1.1K views 3 replies 3 participants last post by  hjhtitan
I need help getting my alternator to charge. Ive hooked a multimeter up to the battery and when i start the car it doesnt jump to 14 volts like it should and goes down to 10-11. Its brand new, been tested and it is a good alternator. Just replaced the voltage regulator. checked the wiring to the alternator and it is correct please help!!
Check the output at the alternator itself. Put your multimeter on the output post that has the wires on it. If that isn't showing 14V or close to it at idle it is a dud alternator. If it is showing a high voltage check the reading on the + battery cable terminal & then on the + battery post itself.
If you have an external voltage regulator, start the engine and connect a voltmeter to the battery + and - terminals. Remove the plug from the regulator and connect a jumper wire to the plug between the A+ and F pins and note the voltmeter reading. If it doesn't move you have a bad alternator. If it increases you have a bad voltage regulator. Do not connect the jumper for more than 10 seconds at a time within a minute or two of each other to avoid overheating the alternator. The output at fast idle with the headlights on should be no less than 14.5 volts.
PS: Unless you want to risk damaging your alternators rectifier bridge, do not disconnect the battery while the engine is running. This is an old generator test and not suitable for alternators.
