Discovered the other day that the 67 will not stay running on idle, it just stumbles and then cuts out as if the idle is set too low. With the choke on it will stay running, but as soon as the choke is off, unless giving it some extra gas it cuts out. So, I figured first place I will check is the idle, start looking for an idle adjustment screw, can't find it, come on here and find a diagram showing where the screw should be.
Go back to the car... fast idle (at least I assume this is the fast idle, based on an image I found of where the idle should be) - check, mixture screw - check, idle adjustment - umm where is it?
Took a bunch of pictures of the carb, maybe someone can help. Red circle is fast idle, blue mixture, any ideas on the idle?
