Calvert racing monoleaf leaf springs
3.9K views 15 replies 6 participants last post by  GradyStang
Those of you that have these leaf springs what did you do for rear shackles? I bought a new stock pair of shackles and the poly rear bushings that come in the leaf springs from calvert are slightly too small to fit over the rods in the shackles. I wallered out the holes slightly in a drill press for fitmet but i was curious what you all did. Also the stock 7/16" bolts in the front eyelets leave a little slop in the aluminum bushings im going to get a slightly bigger bolt to remove that slop.
I saw those. Ive built a few racecars in my time and ive found youve gotta read through the bs of what people think you need and what you actually need. I read why they said you should have the aluminum bushings in the rear and i dont know if i buy it. I just dont see poly bushings moving that much to act like a torque arm. I havent had that problem with past builds making more power than what i wanna make with this mustang. Im all about spending every dollar i need to make the car right but i dont want to waste money on things unnecessary. What are your thoughts on the importance of the aluminum bushings in the rear? Im open to buying them if they will actually make a difference on the car. I dont know though how id press them into the rear rails with the rear rails in the car.
In a leaf spring drag application with Caltracs, any binding in the suspension works against the car during launch. Aluminum bushings (preferably with steel inserts) allow for free movement when the attaching hardware used also allowed free movement. The aluminum bushings do not need to be "pressed" into the frame rails but they should be in a near press like situation. The pivoting action needs to done at the bolts and the typical nuts used are nylocks or doubled up nuts. When properly tightened, these devices will allow the shackle bolts to rotate without much force.
Are you sure that you've got their "mono leaf springs" as opposed to their "split mono leaf springs" as there appears to be a pretty big difference between the two? I'm assuming that you've got their "split mono leaf springs" which on their website it says "All of Calvert Racing’s 2.5″ wide Split Mono Leafsprings are assembled to order with grade 8 hardware and heavy-duty alignment clamps. Aluminum bushings are pressed into the front spring eyes and polyurethane bushings in the rear spring eyes," So, it sounds as though you are supposed to use the aluminum bushings for the front spring eyes and polyurethane bushings in the rear spring eyes. I'd check to see exactly what you've got, maybe make a phone call to Calvert Racing and double check everything before installing. They've also got some polyurethane bushings available for sale, though it doesn't say if they have them for mustangs. I'd call them up and double check with everything that you're doing first before continuing on but I think you've got the split mono's. I don't run those leaf springs but have poly bushings on one of my cars and haven't ever had any issues with it.
Yes i ha
Yes i have the split mono leafs. I know they come with poly but global west and many others argue you get less bind and lateral movement of the leafs if you run aluminum bushings with steel inserts in the back just like the front. I think ill go with the global west de a lum shackles everyone thanks!
I've never seen a kit for aluminum bushings for the rear shackles. I personally made my own on the lathe and the first set didn't have the steel inserts. After a year's use I noticed that the aluminum bushings had worn, mostly due to having a 3" offset shackle for the mini tub (which I moved the leaf springs inboard.) That's when I added steel inserts (basically modeling the Calvert front bushings but shaped the rear bushings like the original 2 pc stock rear bushings) and wear has been non-existent after 8-9 years of hard usage.
The thru bolts used are grade 8 with washers on both sides and a nylock nut, which is never fully snug so they can rotate too. I use white grease as the lube to help the shackle and bolt to freely rotate. I do the same on the front too. I doubt that a leaf spring suspension can get any free-er that that (UNLESS rear sliders are also used in a dedicated drag strip situation.) Since this is also a street driven car, I didn't want to upset the car's normal functioning by adding sliders.
Global West has had their Del A Lum bushing kits available for I believe at least 10 years now, and that's being quite generous. I was looking at them around that 10 year ago time frame when I went to replace the leaf springs on one of my cars but decided on going with polyurethane instead.
