It feels like the ignition is cut off momentarily then back on and if I keep the pedal down it cuts off again and will do this several times then clears up and takes off. Seems to do it only in low (AOD). Full or low tank same thing. Sometimes worse than others like when I just pulled off the freeway. Anyone have a similar experience and (hopefully) an answer?
