Electirc Fuel Pump Relay Help
9K views 7 replies 5 participants last post by  kwkenf
Hello,
Can I get some help with what wires go to what number please? I want to run a interia switch as well.
....87
86 87a 85
....30
#3 · (Edited)
When no power is applied to the relay 30 is connected to 87a:
When power is connected to the relay's energizing coil (85, 86) 30 is connected to 87:
Place inertial switch between relay out (87) and fuel pump +.
In schematic above (JamesWnew's post) the terminals for the FP relay shown are:
Left - 86
Right - 85
Top - 87
Bottom - 30
(87a not used)
Just to confirm I understand.....
Battery to 30
Ignition to 86
Ground to 85
87 out to the inertia switch
Correct
Put a 14 or 16 AWG fusible link (or a 20A fuse) on the wire to 30 where it connects to the battery (usually at the starter relay Bat+)
another question.....is the inertia switch always after the relay?
That is how Ford does it.
