Ok, so I have been troubleshooting the turn signals on my 68 coupe, and I am truly stuck. So far I have:
Now in my current troubleshooting, I recently picked up a TopDiag P100pro Car Circuit Tester and have been able to determine the following:
- Replaced the turn signal switch.
- Replaced all bulbs
- Replaced the rear drivers side tail light socket since it was falling apart.
- Replaced both flashers
- Using the component activation feature test that the new socket does function as expected, and when receiving power from the tester at where it was spliced in will light the bulb.
- The bulb is good
- I have continuity from where the bulb is spliced in, to where the wire end at the turn signal switch connector.
- With the turn signal switch connected, I inserted a probe into the connector at the switch side, and when activating the left turn signal and flasher switch I get power going to that particular pin.
- The light comes on when my day time running lights are on
